guyerst
So I recently finished putting up 2" polystyrene foam board between the roof joists in my garage. I only heat / cool the garage occasionally, so I wanted to keep this as cheap and simple as possible. I know there's a group that will say anything less than a ceailing with 40" blown in is a total waste of time, with the same passion as the diesel dually crowd with their belief in towing with anything less will lead to death and dismemberment on the highways. But for only 2-3 times a month, I'm going to put that much time and money into this.
Cost was under $300 (25 sheets at $11/ea)... relatively cheap.
Plan was to simply cut to fit tight between joistsand press up tight to the roof, turned out to be not so simple as the distance between joists was pretty inconsistent. Ended up being a bit of a pain in the *** to be honest. Turned out ok, but is no way close to air tight. Plenty of places where a portion sags a slight bit from the roof, and gaps between the foam and joist. Garage wasn't ventilated before, and isn't now. I'm not worried about shingle damage, but will be pulling sections here and there to check for mold... I think that's my biggest risk. I'm hoping the not airtight install will end up preventing mold.
Been a bit frosty the last couple mornings, and saw some interesting results on the roof. Where all the neighbors show the frost melting between the joists, my roof shows melting at the joists. Heater hasn't been turned on at all, so I'm thinking I'm retaining the daytime heat and the heat transfer through the joists is causing this. Hopefully this is a sign that this will make a pretty decent difference.
