elm_street
Winter is coming on fast here in the Great White North and I'm starting to think about insulating my 15x26 detached garage. At this point I'm not totally convinced it makes sense since it is detached but I think that at the very least it will help keep the sound down a little bit and hopefully a small space heater will take the edge off those -5C to -10C (23Fto 14F) days (any colder than that will make any garage time pretty short).
Currently the walls are just studs and plywood sheathing on the outside. Ceiling is 8' 4.5" (8 foot studs + base plate and two top plates). Total wall area to insulate is around 550 square feet (two windows, a man door and a 10x8 overhead door take up the rest).
This would be a job I would do on my own and I am leaning towards using 1/2" plywood for the interior walls. It looks like I can get R14 in the walls.
I have two main concerns. First is comfort of doing the actual job, is stone wool (Roxul) better from that standpoint or is it going to be almost as itchy as fiberglass? My second concern is rodents. The building is fairly tight but I'm sure there are enrty points for vermin. The Roxul website says "does not support vermin", whatever that means.
Cost wise in my area it looks like stone wool is about 25% more than fiberglass(59 sq feet per pack versus around 78 for fiberglass, the fiberglass packs are 10% more expensive). In my case this would work out to around $370 for stone wool or about $315 for fiberglass. I think I may have just answered my own question if the itchy factor is what I think it is.
So which one would you go with in my situation?
