My pole building has 5-1/4 inch poles. I already have 4-1/2 inch rigid foam sheets I want to put in the walls of my pole building. I would put the foam against the exterior girts, then the 4-1/2 inch foam then put interior girts up and cover it up with OSB. This would leave an air gap of about 3/4 of an inch between the rigid foam and the interior girts and a total 2-1/4 inch air gap from the foam to the osb.(3/4 air gap + 1-1/2 inch for the girt). The wall would look like this.
(Exterior Metal) - (exterior girt) - (4-1/2" foam) - (3/4" air gap) - (1-1/2 interior girt) - (OSB)
Is this ok to have an air gap like this on the interior side or should I take another approach?
I already have the foam.
Thanks
Thanks
