jkrswld
Howdy folks - looking to gather and finalize ideas on how to "finish" the ceiling in my garage.
The garage is attached with one wall. I've got two newer garage doors that appear to be decent quality and insulated. There are two service doors that are awfully flimsy and include single pane windows. Eventually I'll ditch those for some good steel ones. Oh, there's also a window on the one wall which is also single pane.
The 2 walls that aren't attached to the home don't seem to be insulated. Right now, the ceiling is wide open as pictured. I believe the joists or whatever they're called are spaced out in 48 inch runs, with the roof joists appearing to be 24" on center (so every other one has the board that goes end-to-end of garage). My quick measurements show it to be 21' x 22' and the bottom of the trusses to the floor was 106 inches....or almost 9 feet i suppose.
I have hopes of having somebody out to discuss options to upgrade my electric. Right now there is only ONE outlet besides the two in the ceiling for the door openers. I would like to have at least one or two on each wall with one or two outdoor outlets. And, if/when the ceiling gets done I'll get an electric overhead heater of somekind that I can run on a thermostat. I prefer that over a fuel-based one, but do have natural gas coming to the house and don't think it'd be awfully hard to T-off the furnace line and bring that to garage. Maybe I'll make a 2nd thread on that...
Anyway - what do you guys think? I don't depend on this space for a living and really just use it for average home-owner stuff and basic vehicle maintenance. And making/drinking beers and general hangouts. The goal is to try and increase the livability in summer, but also to keep it above freezing through winter with the option to throttle up heat when desired. I need to cut into the soffits outside to add a couple of vents, but there are two vents in the roof now. If and when we redo the roof I'll go ridge vent for sure.
I was thinking of using some recycled tin/metal from old barns or whatever - do a good job of putting it up and then throwing roll insulation up there. If i couldn't source some used stuff i could probably grab some from a box store. I'm thinking I'd need to tack up plastic if I don't use a kraft-face insulation?
Pics in my album here:
http://garagejournal.com/forum/album.php?albumid=3326
