xscorex
wellok, Im in the process of hanging insulation in my garage. well actually Im in the process of looking at the bag of insulation sitting in my garage and wondering if I will survive the heat if I try to install it. Anyway. the garage is hand built in the 70s or 80s. the guy built the foundation out of cinderblocks, so you have the slab, then a row of cinder block then you have the walls studs sitting on that. He put the walls right in the middle of the cinder block. Now the cinder block wasnt filled with anything and about every other block I can see light coming through.
there is about a 3 inch lip of cinder block all around the building where the wall starts. I hope this makes sense. Anyway. what the best way to tackle this? I thought about cutting a plank the width of the lip and using industrial adhesive to adhere it to the cinder block. I dont even know if that will work. Then go back with some caulk or something and fill in any gaps.
Now, What would be the proper way to fix this.
I seriously think Im going to have to install the air conditioner before the insulation. I almost die trying to do simple things in there with the heat & humidity the way it is
