Insulation Opinion
platerace88
South Dakota
Hey Guys- question, building is sealed off with closed cell, spray foam. I took some of your suggestions and added some extra r value so i should have around r-40 in the upper unit when im done here.
Back to the question...would you run the insulation to the peak or run it to the horizontal truss and over?
Thanks
dcg9381
Austin, TX
I would cover the roof rafters. Basically, they're up against the roof decking and because they are dense, they provide a "thermal bridge" that will transfer heat, even though the roof decking between them is insulated.
yeldogt
I would cover the foam.
If the foam is at all thin for your climate -- the extra insulation will provide an additional protection .. albeit -- tiny.
In a house situation with a large attic space w/o any conditioning -- there is a theory that a small amount of insulation in the ceiling will add to energy saving. Reason: there is a temp difference ... and with a house there are typically leaks.
With your situation -- the space is so small and will be sealed off -- it's better to have that air within the whole building IMO.
