insulation or not on a pole building
mritech1
All right all you builders, I have a question concerning sheeting the inside walls of my shop. As most of you know, I have 2x6's laid flat so as to give me 5.5" between the outside sheeting to the inside of the walls. I have 7/16 OSB covered with Tyvek then Hardi-plank siding on the outside of the walls. My question is this. If I just put OSB on the inside of the walls with out putting insulation in, am I creating a situation where I will have a moisture problem in this 5.5" space in the wall due to temperature differences inside and outside the wall? I don't mind buying the insulation if I have to but I don't plan on insulating the 26ft high vaulted ceiling so the wall insulation will be pretty much a waste as far as trying to keep the place heated. If I did insulate the ceiling for warmth, the amount of heat need for that tall of area would be massive cost wise as well as time wise to get it to a reasonable temp down low at floor level. One option would be to build a false ceiling so to speak and blow in insulation at the 14 ft level?????? The problem with this is that I would take away the large amount of storage available in loft areas. Any ideas? I live in SW Washington state, it never gets real cold for too long like in other locations in the east or farther north. Thanks for any help or ideas.
krooser
Waupaca, Wisconsin
Insulate the walls with 6" fiberglass or sprayed in foam. Do what you need to in the ceiling.
You can solve your heating dilemma by installing a gas-fired radiant tube heater that can hang from the ceiling. Putting the heater at 14' to 18' will not hurt the efficiency at all... it heats like the sun which is a lot farther away (albeit with a lot more btu's!).
I have a tube heater in my shop with a 9.5' ceiling... I had to mount it on a 45 degree angle 'cuz they really like a much taller ceiling. You can recover some of the heat radiated off off your floor by using a couple of fans on the ceiling.
http://site.inetba.com/infraredproductssupply/superiorradiant.html
