I have an attached 25 x 13 garage that I am insulating and heating to 50°F when not in use.
Three of the four walls are 10" concrete with the back and side being below grade and the other side is a shared wall with what will be finished space.
Because the garage is already pretty small I am leaning away from a traditional 2"rigid foam and 2 x 4 studded wall as that will narrow the garage at least 6" (or a foot - see question below).
Closed cell spray foam is an option as well and one that I am considering but then you have wood in close proximity to the concrete and the associated chance of mold - I could space the wall off the concrete and allow spray foam in behind the backside of the stud but then you have a thicker wall.
The option I'm leaning towards is a Barricade wall panel that is 2.5" thick with OSB already attached. See www.ovrx.com for more info on what I am talking about. It offers an R12 and is a vapor barrier as well.
Questions:
1. Has anyone used these or have first/second hand impressions?
2. Am I overlooking another technology?
3. Pros and cons
related:
I am planning to insulate the two below grade walls with this system and on the side abutting finished space insulate on the finished side with traditional studding and spray foam. Is that the correct procedure?
Questions:
3. Pros and cons
related:
