Improved700
Long time listener, first time caller.
I have a existing 25X75 shed on my property, that I am working on. I am going to partition off 30 feet of it, for my shop, and the rest will be cold storage. The building is stick built wood, with 12 inch tounge and groove boards for sheeting, no house wrap of any sort and slate/masonite siding. Side walls are 2X6, 24" O.C., 12 foot sidewalls. Location is Northeast Wisconsin, so heating in the winter is important.
Since I plan on heating the shop portion year round, I want to keep the air infiltration of the walls to a minimum. Here is my thought...
Take 1/2" pink insulation board, and place tightly between the studs, and caulk all around the edges, then use fiberglass kraft faced bats, and fill the cavity. Then cover that with plastic sheeting, then use 5/5" OSB for the wall covering.
Or would I be better off trying to see all the joints of the 12" boards first, then put fiberglass in, and then plastic? My concern would be moisture getting onto the fiberglass through the outside sheeting and getting moldy.
Or is there a better way that I am not thinking of?
Thanks alot... this is a great site!!!!
Kevin in Wisconsin
Kevin in Wisconsin
