Old Moparz
Sorry, I know it isn't actually a "garage" question, but I've been searching all over the internet for an answer & haven't gotten a clear one yet. I've always seen some good info here so I thought I'd post my question.
What I am hoping to find out is whether I can add some kind of insulation layer to the underside of an existing cathedral ceiling without removing the existing drywall & fiberglass insulation?
I'm concerned about the vapor barrier creating a moisture issue & was wondering if there is some kind of product I can install to the surface of the existing drywall on the cathedral ceiling or on the lightweight T&G cedar planking I will finish it with?
The existing R19 fiberglass insulation has a vapor barrier & is almost as thick as the depth of the 2x8 rafters, so there is little or no air space for ventilation. I plan to correct the sag on the exterior by adding 2x furring strips contoured to the sag once I tear off the shingles. A layer of plywood sheathing over the furring strips will add to the air space I need above the insulation.
For the interior, I am going to do something similar by adding 2x rafters below the existing 2x8 rafters & a lightweight T&G cedar planking for a "false ceiling" below the existing drywall. When I do this false ceiling, I am considering the installation of addition insulation. I was also hoping to avoid the removal of the existing drywall & R19 insulation because of the HUGE AREA it involves as well as the height that needs scaffolding.
There's a new beam (girder) I installed with diagonal bracing that acts similar to a truss. It'll remain exposed & give the appearance of a post & beam structure. The false ceiling will be supported by all the new frame work. Here's some photos of what I am doing inside....
