Jayhawk_Aviator
- Joined
- Jun 2, 2015
- Messages
- 123
I have a 40x50 metal shop and am located in Kansas City area.
I had 2" of closed cell foam spray on the ceiling (they sealed everything up), and they sprayed the bottom 3' (up to the first girt). I did that to really seal the bottom edge with the ridges. I am doing the horizontal framing and installing R19 batts around the rest of the sides.
Had a couple of questions:
1) Do I need to install a vapor barrier on top of the batts on the side? I will be drywalling / metaling the sides but wasn't clear on whether that's needed or not. As noted, I think the building is sealed up top via spray foam (no open ridge vent, gable vent, etc.). Th trusses are obviously exposed.
2) Haven't decided if I'm doing a ceiling (to the bottom trusses) or not, but if I do, I assume I should NOT insulate on top of the ceiling? My understanding is if you insulate the ceiling (not the roof), you will want to have gable or ridge vents to facilitate airflow. Since my roof is spray foamed, the whole space is sealed and I wouldn't want to also insulate the ceiling as then the space between ceiling and roof would have no airflow (and not be totally conditioned), resulting in problems, correct? If I want to add a ceiling for anesthetic reasons, I assume I could do that provided I don't insulate it?
Thanks.
Thanks.
