rsevilla
I'm building a 40x28 garage in a few weeks. I've seen on here how folks recommend putting insulation (4'x8' sheets) under the concrete slab. I am building with footers and concrete block walls up out of the ground and then 2x6 stick built on top. The garage will be insulated but not heated. Don't know if I ever will heat it. Some people say it helps keep moisture out. Wouldn't just a heavy mil plastic do this as well? Thanks for your insights!
