midwest farms
- Joined
- Nov 2, 2011
- Messages
- 14
I think I have read ALL of the insulation threads but have a few questions around proper insulation. I know this has been beat to death so I will keep it brief and would anticipate the responses to be the same:
Description:
--Building is an existing pole barn. Not using spray foam due to cost.
--Using 2 layers of 2" rigid foam panels (total of 4") to insulate between poles-poles are 9' apart-not bookshelved (attaching to back side of perlins.)
--Using great stuff or similar spray foam around panels to create airtight seal like this:
--Finishing with metal on walls and ceiling. I have the ceiling details figured out.
--Located in Illinois so hot humid summers-colder winters. Shop has in-floor radiant heat. Will not be cooling in summer excluding fans.
Questions:
1. Do I even need a vapor barrier since I am foaming around the rigid foam board? If I use a vapor barrier I assume this should go on the interior wall?
2. Should I foam around the insulation panels nearest the outside wall or the closest to the interior wall. I want to avoid the pitfalls of a "double vapor barrier" while completely sealing the space.
Thanks!
Description:
Questions:
Thanks!
