bookman51
I had a pole building (72'x40') built two year ago. I had insulation through out all the ceiling and insultation in the walls over the concrete slab for the shop (40' x 36'). I think it is about an R-7 with a white vapor barrier to the inside.
Now I am thinking of putting up drywall and pegboard around the shop area. Is it worth while to put up more insultation on the walls before I dry wall them? I think there is room for 6" batt insulation.
If so, do I have to do anything about the existing vapor barrier? Or, can I just put up more insultation and another vapor barrier on the inside side of it?
I am in Nebraska where the winters can get cold. I probably will be doing electric heat (radiant) and I will be using the shop only occasionally ...I am retired and will be doing retirement projects in the building as the mood strike me!
Thanks in advance.
Bookman
Thanks in advance.
Bookman
