Here is the intercooler I added to my BelAire 7.5hp air compressor.
The compressor is in it's own room with a disconnect right outside the door.
I used an oil cooler with 1"NPT inlet and outlet but had to reduce it to 3/4" because the tank had a 3/4" check valve.
I welded up the frame from 1" tubing for the radiator and 240v fan.
You can see the motor mount from Surplus Center I added to the setup.
There are two auto drains that are connected to a hose that all my drains go to that exits the building through a PVC pipe in the wall into a hole filled with gravel.
Next is to build a shelf for a Dominic Hunter refrigerated dryer and the filters for that unit.
Thanks go to all the GJ, I stole every good idea I saw here to build this!
