owdlvr
I'm working on wiring up my shop, and have encountered a problem I'm not sure how to solve. The shop is built with 6x6 posts supporting the main beams, and you can find 6x6 posts at each corner of the shop, and two spaced out in each wall. There are 2x4 studs, spaced out on 24" centres. 2x4 studs are attached to the 6x6 posts. Everything is done so that the "outside" edge of the studs are flush with the outside edge of the 6x6's. The exterior wall sheathing is already on the building, as is the exterior siding. Essentially the shop is built so that once the interior wall paneling (drywall or other) is affixed, the main posts and beams will still be visible.
On the straight sections of wall, running the electrical is easy. I simply had to go and buy a long auger bit, and drill right through each 6x6 post (and the 2x4 attached on either side). My problem is the corners. How do I drill to run the wiring?
If it matters, I'm going to need to pass multiple runs of 12/2 through the posts for lights and receptacles, and also wiring for 240v lathe, compressor, hoist and more (wire size not yet determined).
This is my first time wiring anything household or shop, so I'm hoping there is a relatively "oh yeah, you just do ____" type of solution I don't know about?
-Dave
*note: just realized my fat fingers called the studs 2x5's on the diagram, not that it matters...but they are 2x4's.
- Can't drill through the post on a 45deg angle, I cannot position the drill in anyway to make it happen, without pulling off the outside siding and sheathing.
- Can't drill a hole from either side, and hope to somehow fish the wire through a 90deg bend...right?
- Can't go up and over through the ceiling joists, as supporting post meets a roof beam and the problem is exactly the same, different only in geometry.
- Would *prefer* to not have wiring or conduit visible, as I'd have to do this in 4 places.
-Dave
