Interior corner trim for steel?
Cetnor851
Mi
Finishing off the interior of my barn and the top 4’ will be steel and bottom 10’ will be plywood, but not sure how to trim out the inner corners where the two pieces of steel will met not sure if you just put J channel back to back or what.
racecougar
Missouri
Inside corners are available. It looks like these are the best photos I have on this computer to illustrate.
Firebrick43
West central Indiana
the make interior corner for all practical purpose is back to back j channel
https://www.menards.com/main/building-materials/pole-barn-post-frame-materials/pole-barn-post-frame-building-trims/12-steel-j-trim-with-f-channel-large/britewhite1564367-08/p-1444448548562-c-5720.htm?tid=2441596278172883567&ipos=9
This makes hanging ceilings a lot easier as well.
csp
Franktown, CO
I used that inside corner trim both in the corners and where the ceiling and walls meet.
islandkent
PEI,Canada
I just used vinyl inside corner trim. Cheap and real easy to use. Clean looking.
Used vinyl j-trim on the ceiling. Cheap and real easy to use. Clean looking.
Is there a echo in here? lol
beatuptruck
Calgary, AB
I used 1 J-Trim. terminate the first piece of siding going into the corner with no trim, install J-Trim ontop and continue out of the corner with the 1 J-trim.
C
Cetnor851
Mi
Any pictures? I think I might steal that idea, cheaper and in stock lol
islandkent
PEI,Canada
Sorry Cetnor.
Just seen this. Here's a couple of shots. This is the only corner you can see. Rest are full of shelving. lol Used it around the windows and doors also. J trim that is. I used that plastic "wood" for my window sills and trim around the windows and doors. Solid white all the way through. Easy to clean. Any here is the corner trim and ceiling trim.
welder57
You can Purchase from MBCI or other suppliers, either a flat inside corner or a corner with extra bends to go over the ribs, customer must tell them how tall is the panel ribs.
