joe_pinehill1
I would like to mortise existing door jambs with my router. The jigs I have are for unhung doors and jambs. Anyone know of a template that can be used on a jamb installed with door stop?
Yeah, chisel! Just do it by hand. I did this yesterday. I have cheap Stanley #50 **** chisels and drove them with a 20oz slimline trusty cook dead blow. Consistent blows gets you consistent depth. Takes a few minutes. Use a sharp chisel.I've removed the stop when mortising for hinges with a router. If there is a better way, I'd love to learn about it.
This is the way for one or two doors.Yeah, chisel! Just do it by hand. I did this yesterday. I have cheap Stanley #50 **** chisels and drove them with a 20oz slimline trusty cook dead blow. Consistent blows gets you consistent depth. Takes a few minutes. Use a sharp chisel.
Guys think they save time using power tools. If you are doing a hundred, the set-up investment is worth it. If you are doing one, you’ll be faster by hand.
I to make it simple I could use a square hinge.A quick marking with one of these, Stanley 95 **** gauge, quick scoring with a knife, whacking a chisel a few time, and done.
https://www.tooltique.co.uk/the-vintage-stanley-no-95-****-gauge/
If you are less good with a chisel, a router plane can clean up behind you.
Stanley No 71 Router Plane
Made in the 1930s, this Stanley No 71 router plane is nickel plated and has painted hardwood handles. The finishes are in very good condition. Some abrasion of the sole, but no gouges or pitting. The blade is in excellent condition.loonlaketoolworks.com
If you have rounded corner hinges, built for routers, someone makes a rounding chisel, but of course I can only find the one that converts router cut corners to squares. An appropriately sized gouge is probably more expensive than the little gizmo.
Good grief your hinges have huge radii.
This one is really helpful.A quick marking with one of these, Stanley 95 **** gauge, quick scoring with a knife, whacking a chisel a few time, and done.
