Interior metal siding/wainscoting question
MushCreek
Upstate South Carolina
I just put up metal wainscoting in my shop. It's a little over 4' tall, looks good, and is spark-proof. If you've done this, how do you deal with the gaps where things like workbenches **** up to the metal? The ridges are about 3/4" tall, creating a series of spaces for small stuff to disappear. I know that they make foam closure strips, but they seem kind of light-duty for a shop environment. I guess I could make a pattern and make wood closure strips. What have y'all done? I have two benches and a utility sink that **** up to the tin.
racecougar
Missouri
I put pegboard up at the back of two of my benches, and a backsplash on the third. You can see the two with pegboard here.
MushCreek
That ship has already sailed. I had a bunch of 48" pieces of galvy tin. I put a PT 2X4 on the floor, then the tin, so it's about 52" tall. The benches are made from old kitchen counters, so they have a built-in backsplash a few inches high. The sink, though, has nothing. I guess I could make a metal backsplash to keep stuff from falling behind it. I would like a more finished appearance, though, even on the work benches. Whenever I see a gap, I hear a little voice calling out to small objects. My benches are mounted on metal cabinets, so there's no access if something falls back there, short of moving the whole bench.
Codyboy
S.E. TEXAS
They make 3/4" caulk.
ETA
They so have some 1 "caulk, but its hard to find because they're always sold out.
CraigStu
Blacksburg, Va
I once ate in a ribs joint that did similar to Southernillinois. But they did more like a 1x1 then a piece of something that was about 1/4" thick and maybe 1.5 wide. They nailed that to the surface of the 1x1 so the top edge was flush and the bottom edge overhung the tin by that 1/2".
66Caprice
Stanwood, Washington
Zugec
Rip wood strips to fit ridges or you can use angle/flat bar which is stronger than foam and will keep stuff from slipping through.
