inane2
Hey guys!
Slowly working on remodeling a 36'x48' shop that was on my property when I moved here. A little about the building up front :
- 5.5" concrete slab
- Trusses on 6' centers
- 2x6 girts (flat) on 30" centers
- White ribbed metal panels on the ceiling, 10' tall
- No soffit on either end on the building, trusses were cut flush with the posts
- Heated by a barrell wood stove
I went back in and replaced metal on two sides of the building due to damage and very badly faded, chalky paint. Once the new metal was up, we went in and toe-nailed in 2x6 bookshelf girts on top of the flat girts (still retaining 30" centers).
I've bought R-19 batts, 15" wide and 6.5" deep, kraft faced. These will fit perfectly between the new girts. Once installed, going to cover the walls with 7/16" OSB. The corner where the barrell stove resides will get white metal instead of OSB.
I went ahead and bought new metal for the roof. It will be spring before it's installed unless we get a nice weekend sometime soon. Before laying the new metal roof down, I'm going to install "Low-E" radiant barrier. 1/4" thick, basically double bubble with aluminum foil on both sides. This will be installed over the purlins, beneath the new metal. Also, there is currently insulation batts between the trusses, on top of the metal ceiling. This stuff is in rough shape, so I'm going to remove it and use blow in insulation.
Two questions:
1. Should I install a plastic vapor barrier over top the batts in the wall before I install the OSB (or metal in the stove corner)? Any recommended thickness?
2. Should I install tyvek or house wrap against the inside of the metal before I install the batts in the wall cavities? Looking back, I had a perfect chance to do this when the metal was off. I've read different opinions on having bare fiberglass against metal panels.
To help you visualize, here is a pic before I installed new metal and bookshelf girts:
View media item 23543
Thanks guys!!!
Two questions:
Thanks guys!!!
