Interior sheathing ideas?
justbarriault
Tilton, NH
I'm getting ready to cover the inside of my shop. I like flame resistant material such as sheetrock, but I like the versatile plywood where it's rugged and I can screw to it. I was thinking plywood for most of the shop and maybe concrete board in my main work area/tool area where cut off saws, grinders, etc will be used the most. I have no building codes, but would like to keep the insurance company happy if the places ever catches on fire. Thoughts, ideas?
J
justbarriault
Tilton, NH
NUTTSGT
Northern Central Ohio
I have never seen an insurance company not pay due somebody not having "the proper" wall covering. That being said, homes burn down everyday in the US and they have drywall/sheetrock. The insurance companies write checks on those insured policies.
Thumper68
Duluth MN
If I was to redo my walls I would go with osb/plywood covered by the Masonite with the melamine coating.
I have the covering but no plywood backer and it is a pain when hanging things, never a stud where you need one.
Cyberbear
California
There are many options for wall coverings, but to have both fire protection and easy mounting ability for tools, wall cabinets, etc., I believe a minimum of 5/8" ply under a layer of sheet rock will do the trick. Take pictures as you go and you'll have proof of what was done if you believe it is necessary, not to mention you'll know better where your wall studs are.
Gerald O
NC
It this a stick-built shop or pole barn?
Do you really need to randomly hang objects at every place on walls?
I did the back wall in my shop with cement board for putting up a brick veneer. It's not easy to work with, expensive, and isn't particularly helpful for mounting things on other than tile or brick.
Put up your sheetrock, it will give you the fire resistance you want.
Then if and when you find a particular spot that you need to hang something on the wall, put up a shelf, bracket, pegboard, or whatever in that spot. Unless it's pole construction, finding a stud to mount to is not a problem.
JerryB
North Coast, CA
IMO, best of both worlds: My hanger and shop are all 100% insulated, sheetrocked, taped and painted. When I really want a solid load bearing surface for placing or hanging tools, I cut and paint a piece of plywood, then screw it through the sheetrock to the studs. Very permanent, but easily moved in the future.
Jazz1
Thunder Bay On.
5/8" thats pretty much standard here for garages. OSB,,,we put it on walls of neighbours outhouse years ago,,was not impressed
J
justbarriault
Tilton, NH
i'm thinking I might just stick to the original plan of plywood everywhere HAHA. This is looking like it could get complicated and pricey to do anything other than straight plywood or sheet rock. And me and sheet rock don't see eye to eye when it comes to installation...
