Interior Vent Range Hoods and Microwave
Two Pump Chump
N CA
I see that there are ductless interior venting gas range hoods available that utilize replaceable carbon filters. Are there over head microwaves that have similar venting ? My application makes running conventional venting problematic. Thanks
EDIT: after some time my lil Samsung chat dude confirmed that tbhis model has carbon filter interior vent.
Joemctag
Outside raleigh nc
I don’t think there is a worse idea than an interior vent hood, especially on a gas range. Just sayin.
Either his kitchen was built with no exterior venting or he’s re-configuring his kitchen. Either way, it’s not right. On the other hand, there are two kinds of people who use stoves: those who turn on the vent and those who don’t like the noise. No matter that they’re putting all this steam (water vapor) into their house.
I actually like the old style that go right through the wall to outside. Louvers open when you turn it on. They’re powerful.
rjacobs
Dallas, TX
its likely not legal either.
We had to have a certain CFM size vent hood for ours based on the BTU it put out.
Zeke
I don't think those exact words describe any product for sale. IDK about the filters you mention, but carbon monoxide CAN be removed (or captured) by an 'activated' carbon filter. In the kitchen you would be changing the filters quite often. AFA grease, odors and particulates go, a ventless filter system can work. Requires a lot of maintenance. At that price point I doubt you'll be getting anything that will preserve your health.
T
Two Pump Chump
N CA
Thanks Zeke. I gather it merits attention when range top cooking and making a smoky mess. All I know is that conventional venting my case would be a nightmare. I dont even know how I would do it. Much to learn . . .. .
It's a new build. The design does not lend itself to a range/oven vent. If you saw what I have you would agree. At least it's not in California where it would set off the sprinklers.
For the sayers of doom, I havent had to use, been required to use our existing range vent in the existing house in years. We dont burn $hit very often and it's not a big deal. Grill and Bar B Cue outdoors as God intended. With cold beer !
dogdog
If you can go for a vented outside unit, might be better, especially if you do a lot of cooking. 6" or 8" diameter ducts are common. over head microwave looks cool but it's just looks. not practical if you are cooking a lot....
Some one I know, used to have a filter kitchen vent... not vented outside... it *****. Filters are expensive, very expensive. this one is Squirrel cage design so it moved plenty of air, capture plenty of oil, just that it doesn't filter smell too well.. NFG.
larry4406
Northern Virginia
Lot of folks think vents must go up then out. Open your eyes.
I have done many where they go down then out. Required due to LVL headers, steel, etc. Have even built bulkheads/chases to achieve.
Trust me, you will be much happier with an externally vented hood/microwave,
Zeke
New build then why gas? Induction is the way to go. You will still get steam, some with oil in it, some odors, a little smoke now and then. The recirculating hood was designed to handle a small amount of that. The worst offender is a gas oven.
I want to stay on topic but one has to ask, if a new build why is it difficult to vent to the outside? Under floor units are installed all the time. IDT they work that well, but the brand makes a lot of difference.
MarcSeattle
Seattle
I'll nominate the idea of an island range with no range hood at all. Extra points if it's a gas stove. Extra extra points if the house is over $2 million.
