I will be using OSB for my interior walls and do not want to set the edge of the panel directly against the floor to prevent any moisture/water from wicking into it. I am wondering what other have done.
One thought is to have a 1"x3" pvc molding on the bottom against the floor and then set the 4x8 ft osb panel on top of the molding creating a 3 inch offset. This would keep the bottom of the OSB off of the floor to prevent any water or moisture from wicking up into the osb.
I have a typical pole building.
Thoughts?
Other ideas?
Has anyone done something similar?
Thanks
Thoughts?
Other ideas?
Thanks
