Was going with pro rib on the walls. Wonder how finished drywall would look instead.
D Dave Maxwell Well-known member Joined Sep 21, 2011 Messages 865 Location Kickapoo illinois May 19, 2012 #1 Was going with pro rib on the walls. Wonder how finished drywall would look instead.
N NUTTSGT Super Moderator Staff member Joined Sep 14, 2009 Messages 51,059 Location Northern Central Ohio May 19, 2012 #2 One of the problems with the pro rib metal siding walls is hanging stuff. You don't have a tradtional flat surface for stuff like wall shelving.
OP D Dave Maxwell Well-known member Joined Sep 21, 2011 Messages 865 Location Kickapoo illinois May 19, 2012 #3 Good point. Orginally thought about metal because of welding and stuff. But like the smooth liok of finished drywall.
N NUTTSGT Super Moderator Staff member Joined Sep 14, 2009 Messages 51,059 Location Northern Central Ohio May 19, 2012 #4 Dave Maxwell said: Good point. Orginally thought about metal because of welding and stuff. But like the smooth liok of finished drywall. Click to expand... Put the drywall up and a sheet of aluminum diamond plate where you do your welding.
OP D Dave Maxwell Well-known member Joined Sep 21, 2011 Messages 865 Location Kickapoo illinois May 20, 2012 #5 Figure the drywall will help with noise reduction also. Don't want noise escaping
D djkeev Well-known member Joined Feb 8, 2012 Messages 1,223 Location North Western New Jersey May 20, 2012 #6 For welding areas, consider using Hardie Cement Backer Board. It's cheap, easy to work with and fire resistant. http://www.jameshardie.com/homeowner/pdf/backer-install-us.pdf Dave
