Hey guys, we just moved in to a home about 4-5 months ago and during the first week, started having problems with the AC. The previous owners had a NEST thermostat on the wall but replaced it with what looks like the older original thermostat that the house came with. It seemed like every few days, the AC would not automatically kick on, the temp would be low 80's in the house and you could set the thermostat to any temp, nothing would happen. I had a newer digital thermostat that I used in my old apartment and it worked fine so I swapped them out. Another week or so goes by and it's back to intermittent again. I try new batteries in the thermostat, no help, I try the old thermostat and it starts working again, but only a few days then it's back to same old stuff. I finally put the newer thermostat back up and for a month or so, it has worked fine but now it's low 80's again and burning up in here.
Apparently the thermostat is NOT the problem, since it does the same thing with both different type thermostats. What would you check first?
Thanks
Thanks
