International Forge Co. 3/4 ratchet
davethorik
Norka, Ohio
Picked this up today, some kinda funky Craftsman variant. Looks almost nickel plated.
Selector looks newer. Detent ball is sunk. Works well. Came with an unmarked sliding T drive stud, and 2 rusty sockets. One is a 5 band Plomb Los Angeles pictured.
Didn't find much on Google.
Provincial
Near Salem, OR
I have an International Forge 1/4" drive set in a metal case that is fairly complete. I have not seen any other example of this brand until now.
r_olson_06
SD
Same here. I have a 1/4" ratchet but have not seen any larger. Looks to be a Craftsman rip off.
transam81
Looks sort of like a mish mash. Proto head, craftsman handle and perhaps a New Britain middle.
D
davethorik
Norka, Ohio
Transam, I think it was the late 40s/50s all Craftsman rats had heads that looked like this. Box head I think they're called. Edit: pic added oil hole.
To me they most resemble Snap-on, but were Moore Drop Forge. Craftsman 3/4 rats kept this design while the smaller sizes went through many changes. Newer models have been upgraded to quick release. You might be able to buy it new as a Chinese Craftsman today.
The grip looks Craftsman except the letters are forged-in and protrude from the surface, Craftsman are stamped into surface.
The middle is the truly weird part, I thought of Truth ratchets at first.
:lol:
I did some major digging in the garage. Haven’t seen these in a while. A 3/8” and 1/4”.
I also noticed the 3/4 has that hump like you see on a Truth. The blank panel is interesting as well.
snapmom
Florida
The stuck ball, let pent. oil soak into it for about a day. then hit the back of the plug with a hammer, or just bang the plug against something steel. This has often working for me.
twertsy
Reedville, VA
Earliest mention I can find of them (newspapers) is 1950, Clarence R. Balek - Pres. Mr. Balek passed in 1961. The appear to have been known for Aluminum tool forging more than anything. There's only one mention of them past 1961, a job advertisement (looking for telemarketers) in 1986.
I do see Truth in the spring detent in the handle. Oddball for sure.
D
davethorik
Norka, Ohio
That makes sense, after Provincial posted pics of his set I saw Chicago on the box, altered my search and found a couple aluminum pipe wrenches.
The ratchets appear MDF sourced, and the smaller ones are doppelgangers for Craftsman, but my 3/4 is unique. Interesting.
I did spray pb on the detent ball. Tried snapmoms trick, no dice. I found a large nail set that fits on the ball, pushed as hard as I could and no movement. I then hit the nail set with a ball pein hammer and that got the ball loose. I can now push the nail set on the ball in by hand, it has a very strong spring force behind it. However it appears to be excessively double-staked from the factory and the ball cannot protrude far enough to engage a detent. Or there is still crud in it. I filled the inner cavity with pb and its soaking again.
Guess I'm on the lookout for a craftsman 3/4 rebuild kit. Maybe.
Me too. TRUTH was providing that style 3/4-inch drive ratchet to MAC in the late 40's - except for that flat handle at the end.
