Mike Cohagen
- Joined
- Feb 23, 2012
- Messages
- 46
Hello,
I make various things out of sheet metal (mostly aluminium, sometimes copper or brass); from women's handbags, to coal miners-style lunchboxes, to guitars. Some of my work can be viewed here, although I have not updated it in a while and am working on a new website.
Currently, I am working on a line of women's handbags made of aluminium -- here is a prototype of one of the models:
This was completely hand made and took over the course of two weeks to complete. I would like to be able to make these much more quickly and precisely, yet still have them be completely handmade.
The process I use now involves hand nibblers (Jilson SuperSnips/Edma NR1 Super Coup), and hand snips (Wiss A11). This is the most time consuming part of the process as things always need to be filed and hammered so they are straight.
Basically, I need a press shear but I do not have a large enough workspace or budget at the moment. I have been looking into bench top guillotine-style shears like this, which seems like it would be great as I could tuck the shear under one of my work benches when it is not in use.
I have also been looking into the 3-in-1 (shear, brake, roll) tools that various companies sell but it seems as if they are junk. They also weigh about 325 pounds so they cannot be moved around easily.
Because I am working in the inside of a house and space is an issue, I need:
-Something that can fit on top and under my bench and is not too heavy (80-100 pounds max?)
-Can shear at minimum 20 gauge aluminium (18 would be great)
-Can shear at minimum 12" wide although wider would be better
-Something that is fairly easy to set up for quick cuts
-Can shear perfectly straight like a press shear
My questions are:
-Can guillotine-style shears like the 2001EVO achieve clean, straight cuts like a press shear, or do they bend the edges of the cuts like tin snips? Does the waste side curl up or does the tool shear the metal in half?
-If not a guillotine style shear, does anyone have recommendations for something else? Are there decent bench top press shears? I'm open to any ideas.
I would like to keep this under $500 if possible -- something used would be probably be best.
Any help would be much appreciated!
My questions are:
