Inverter generator decision
nirion
central OH
I recently sold my small non-inverter generator and am looking to pick up a new inverter one.
I am considering three different ones right now.
1) Wait for another Wen 2000 deal at Woot or similar for about $389
2) Sportsman 3000 max/2800 running for $499 (on sale at Home Depot through 4/9, normally $799-849)
3) Champion 3100 max/2800 running for $699 at Costco
I have a larger non-inverter generator, so this one would be use occasionally with the camper or for other things when I only need lower wattage, quieter, or longer run time per gallon.
The 3,000 watt ones seem like the better choice because of the 30 amp RV outlet (I have the 50 amp to 30 amp adapter that would fit) and the overall higher output. I have heard the Champion is a better quality, but for my limited use, is it worth 40% more cost?
The Harbor freight one is a little cheaper and lighter, but also less output.
I am leaning towards the Sportsman, but appreciate the input.
Falcon67
Merkel, TX
I've had good luck with non-inverter Champion units. The 3500 we have has run our race trailer nicely, been in use for 3 years. It's run as much as 3+ days straight. We can't afford an EU7000, so we upgraded to a Champion 6500/8125 for use with the new trailer. $5000 vs $750 LOL.
woodrail
Lorain, Ohio
Honda 3000 or a pair of 2000. It will only hurt once (for a while;) ) there is no substitute.
OK, a yamaha. These are very good also......
Pick your favorite color. Your camping neighbor will thank you.
N
nirion
central OH
While they are very nice, $2000 for the blue or red is a lot more than I'm looking to spend for my limited use. The camping use will probably less than just around the property where there is no electric.
Bobaloo22
Orangeburgville?, Va
I'm thinking very hard about buying the champion also. Going to use it to run my 13,5ac in my travel trailer. I have only heard good things about them but still not 100 percent sure.
Bob
cajunfirehawk
Ms Gulf Coast
I had one Honda eu20001 that had me living like a king with an a/c window unit after katrina for over a month, it works so well I have another one in the garage in the box, never been started. YMMV
What brand/size A/C do you have in your RV ? If it is a 13,500 BTU A/C then a 2000W generator will likely start it IF YOU ADD A "SOFT START" TO THE A/C !!
Definitely a bonus ! If you have a big RV, it likely has 15,000 BTU A/C and you will need a 2 generators slaved together or a 3000 what unit.
The Wen is identical to the new HF 1600/2000W inverter generator, just different color plastic.
The problem with HF and Wen, is servicing location.
My gut says, buy the HF unit with the extended warranty. The size is very attractive ! Just be prepared to buy a second one if it won't start your A/C !
stage20
pcola FL
hondas are on my local craigs all the time for 6-700, i would highly recommend. they run as they should, and are the quietest out there, no matter what other manufactures ratings are.
Showkey
"MEMBER EMERITUS"
Wausau WI
The Westinghouse, Honeywell plus several others all rebranded are maginal at best. Read the reviews on Amazon and there locations.
N
nirion
central OH
My fifth wheel a.c. is 15k, so the 3000 watts ones are looking appealing.
I'm going to look around for a home depot coupon to make the deal a little better and am leaning towards that route.
I'll also peruse Craigslist for any uses eu3000 or similar Yamaha.
Thanks all!
American Locomotive
Rhode Island
I've seen more than one of the cheap off brand inverter generators burnt up. Usually the inverter fails.
If I wanted an inverter generator, I'd probably go Honda or another Japanese brand.
1969
East Coast
FYI.......... Honda generators are made in China and India. I was going to by a Honda, but started looking them over and guess what........ China and India.
Showkey
"MEMBER EMERITUS"
Wausau WI
Agree ^^^^^^^^ the cheap units use cheap, poor quality components, it's the only way to build to that cheap price point.
My two Honda EU2000 were made in Japan ........but.........have seen there are multiple world wide locations where they are made.
One EU2000 will start my 15k RV AC unit when the SC unit is equipped witha soft start capacitor.
China and India can make decent stuff or junk.
True ! You have to be careful how you spec your item, down to the smallest detail. Then you have to have proper Quality Control and Quality Assurance. Finally, you need to do "sampling" of the items at your local warehouse/distribution center. These things all add cost, which is what the bean counters are trying to afford by going to China or India to start with.
doorfx
Calgary ab. Canada
Really? My Honda 2000 wouldn't even start my 13.5 RV AC even after I installed a soft start cap. My buddies 2600 Yamaha would just barely if nothing else was on.
American Locomotive
Rhode Island
I said "off brand", not Chinese. Honda has a reputation for quality, and they work hard to maintain that regardless of where a product is made.
Honda ensures the machines meet their standards and use high quality components. The offbrands just fling thrm out the factory without a care.
Falcon67
Merkel, TX
Thanks all!
The 13.5K BTU unit in our race trailer pulls 21A in 100F weather. Guy we race with has a 15K in his 28' trailer - he has his eu3000 for sale because it will not start/run the AC unit. He runs off an EU6500 inverter. It's also for sale, $3200.
N
nirion
central OH
I decided I didn't really want to go the route of two 2000 watt units in parallel. I also looked at a Honda eu3000, but couldn't justify the $2000 price tag for my occasional, non-essential use.
This left me with the Champion for $699 (which I was leaning towards) and the Sportsman (on sale through yesterday for $499). I ended up ordering the Sportsman because Kroger had 4x fuel perks ($500 gift cards = $60 in fuel savings) and my Chase card had a 5% cash back offer for grocery stores this quarter (since Kroger qualifies, another $25 in savings), putting the total price with tax closer to $450 (after the fuel savings and cash back).
It should be delivered this week and I'll give it a try. If it doesn't work well, I'll take it back and go with the Champion. I'll post back after I get it.
Thanks all
The 125v 30a RV outlet (NEMA TT-30r) isnt as versatile as a 125v NEMA 5-30r or 125v/250v 14-30R since its only found on RVs....just means u have to carry an adapter around if u want to use it with other equipment...
Anything Westinghouse is probably not a good idea to buy right now since they are going through bankruptcy....amazing, that a company, which is one of only a select few in the world who can build nuclear reactors, is going through bankruptcy....corporate america.... :evil:
American Locomotive
Rhode Island
The Westinghouse brand of generators likely has nothing to do with the Westinghouse that just filed for bankruptcy. The Westinghouse "brand" is licensed to companies all over the world. As far as I can tell, TECO currently controls the Westinghouse brand for generators and motors.
slow
near Orlando
Keep an eye on Amazon, I picked up a new inbox honda eu2000 companion for 599 last year. Sold by third party but filled by amazon. Other dealers were playing pricing games and charging $399 for shipping, but mine was free prime shipping!
finn
The UP, God's country
I bought two of the 2000w Champion inverters for my fifth wheel a couple of years ago..
Surprisingly, Menards had the best price online / deliver to store. I think they were $399 each at the time.
Dead nuts reliable so far, and relatively quiet, but not as quiet as the Honda, which is over 200% of the cost of the Champion.
I run one in the evening and morning to charge the camper batteries, and both for the a/c.
mike93lx
Richmond, VA
Hi, It is important to consider all aspect of inverter and your requirements. Before buying any inverter you have to check reviews of all inverter brands at inverterreview.com. This may help you to pick best inverter.
This doesn't reek of spam at all
sselander
CT
If you look in a Westinghouse generator manual it has this info:
MWE Investments LLC
777 Manor Park Drive
Columbus, Ohio 43228
service hotline: (855) 944-3571
google that and you will find a business description which also states they also do business as West Pro Power Systems and are an importer.
So they are just licensing the Westinghouse name.
N
nirion
central OH
I ended up with the Sportsman. I have probably only put 15i-20 hours on it. I used it while we were building our house and also in the barn without power. It starts my 15k rv ac, but not my craftsman 30 gallon/5hp compressor. It is quiet, but not Honda or Yamaha quiet. It is fuel efficient.
It doesn't start on the first pull like my old Coleman non-inverter, but usually after 5 or 6 pulls.
checkthisout
Got a used Yamaha 3000 ISEB about 4 years ago for $1000.00 (used barely). I made it remote start with automatic choke and what not.
The thing I like it about it is the fact that it has large handles on either end. Casters that roll over anything and it has the unique feature of being able to boost to 50 amps for around 30 seconds or so by utilizing energy from it's starting battery to supplement output.
It starts large trailer A/C units in high heat without breaking a sweat.
Falcon67
Merkel, TX
LOL, then we spend the $4000 on an EU7000is after all. :thumbup:
Falcon67
Merkel, TX
Westinghouse also makes a 4200w inverter for about $610. Home depot sells it. The model is ipro4200.
True - open frame inverter is better than a non inverter. But the 62 dB listed is not THAT much better than the 68 dB for a regular Champ 3500. In comparison, our eu7000 runs about 58 dB at full song, way less at partial load. And it will vary engine speed based on load applied. Not cheap but worth every penny so far.
One thing many people do not know is that many (most ? all?) inverter generators can run "paralleled", so two 2000W generators make 4000W. Why ? some of us old farts can't hoist a 3000W or 4000W generator into the back of a pickup ! Also, even though inverter generators throttle down, if you only have a 1000W load, only run ONE !
Bretny
Dutchess county NY
3uThats a decent champion.
I thought this was an inverter generator thread not a generator noise thread.
Westinghouse does sell a Ipro4200 that has quite a bit more run time but looks the same as the igen4200.
