Hi there.
I have a 120V firman 4000W inverter generator that has a 30A RV three prong plug. I’ve already confirmed the inverter has a floating neutral and I want to use this inverter with my transfer switch.
I have an adapter that I use to convert the three prong RV plug to a 4 prong twist lock where hot appear to be jumpered. So from the adapter I get 120V from L1 and neutral and L2 and neutral. The inverter then runs into a twist lock inlet that goes into my house and to the transfer switch. All the 10 circuits I have on the transfer switch are single pole so I have no 240v applications. When I power up the generator and plug it into the inlet it immediately trips and shows an overload light. The problem is I have all the loads turned off at the transfer switch so everything is in line mode.
What could be happening?
Here is my gear
Firman 4000W inverter generator model WH03242 link: https://firmanpowerequipment.com/products/wh03242
I’m using this adapter: Parkworld 67867 NEMA TT-30P to L14-30R 1-Piece Adapter, RV 30A TT-30 Male Plug to Generator 30A 4-Prong L14-30 Female Receptacle https://www.amazon.ca/dp/B08F4YQLBX/?tag=atomicindus04-20
Finally I have the Reliance Controls manual transfer switch model CRK310
Here is my gear
