I currently have a 4 ton WSHP that operates off an open loop well system. Its going on 20 years old and still works fine. But thinking about options for the future. One of the issues / problems with a conventional heat pump system is locating a spot outside for the condenser unit mostly because they are so big and ugly (wife says). I started looking into the inverter units mostly because the outdoor unit is much more compact and less obtrusive. WIth the high seer ratings I am thinking the efficiency may actually be better than the older WSHP and well operation now.
Looking for any feedback specifically regarding the inverter units that use a typical ducted style evaporator indoor unit. I want to keep my current duct system and not use the mini split head units. I have a location that would work for the outdoor unit that I can get power to and the refrigerant lines. Curious as to the life expectancy, how well they work compared to a conventional heat pump, drawbacks, etc.
