IR 119max is a beast
Nthill93
Long Island, NY
Had to reseal a piston on my 4in1 bucket and I couldn’t get the gland nut off. I tried a gland nut wrench with a 3/4 breaker bar, spanner wrench with a big sledge. Busted out the torch got it hot and soaked it with kroil. Nothing. Ripped 3 vices off my work benches need to bolt them onto a steel plate now. Tried el cheapo harbor freight air hammer and it wouldn’t budge. Figured I’d give the 119 and chance and ordered one. Hooked it up with 1/2” air hose and blasted it off. It cut half the gland nut off but it got it. I am impressed. I wish I had it when I had to unfreeze my bobcat quick tach pins
GeoBruin
I think that's the direction I'm headed, especially after the Torque Test Channel episode.
Torque Test Channel
The TTC Garage
The 119 is sweet, and not expensive. Can't think of a thing to fault it for.
Been working on testing and developing a prototype .401 shank air hammer, and to be honest 119 is a hard act to follow. It's just good.
  • Like
Reactions: MM8
GeoBruin
Please tell me this new prototype air hammer is going to be co-branded with TTC or at least have "TTC Approved" on the box!
RedneckWelder
The Ghetto Kingdom of Methlandia
I have the 118 and it has made many larger cylinder glands move. It’s also fucked a few up lol but they deserved it for not coming loose.
works great on spinning out stripped out drain plugs or other fasteners as well. The trigger control is exactly what a mechanic needs for delicate air hammer work.
N
Nthill93
Long Island, NY
I made my decision based on the TTC video thanks guys for all you do. Next big hurdle is the piston nut. My 2767 impact didn’t work but I was using a 3/4 to 1/2” adapter so I’m sure that stole some torque.
RedneckWelder
The 2767 isn’t what it’s cracked up to be, doesn‘t even match a real 1/2” air impact.
Depending on cylinder size a 3/4 to 1” impact is needed and for the larger stuff you’re talking about a hydraulic cylinder bench to break that nut loose. The only stuff I’ve been able to use a 1/2 inch impact on successfully is very small cylinders off a utility tractor.
you might have luck going to a friendly local tractor or equipment shop and asking them if you can chuck the rod into a vise and break it loose with their larger impact, repack on your tailgate and have them tighten it.
Zewnten
Second going to a dealer and having them break it free or a cylinder shop if you have one in your area. We used to do it frequently for people at my previous dealer. I also built my own cylinder bench if your planning on doing this frequently, but you better be a decent welder as those rod piston nuts are put on with some serious power in bigger sizes and age.
N
Nthill93
Long Island, NY
Going to give the 1” aircat a shot tomorrow. If not I have access to a hytorq at work. Not a huge cylinder it’s off a skid steer 4in1 1 1/2” piston nut.
Sugarfryz
Thank you for being the only one to agree with me that the 2767 is not as great as they say. My ir 2235ti eats it for lunch. It’s good for what it is, but I found if it doesn’t immediately break a bolt free, it’s just not going to.
vwpieces
Hills, PA
Been on the hunt for deal on the 119MAX because of Torque Test Channel vids
Finally found one a couple days ago as Amazon warehouse deal. Not a crazy savings but scored the "Kit" for $110 shipped, regular price is $140.
It's the kit with 5pc bits. Still wanting the hammer head bit as that not included.
Should be here next tuesday, no prime...
N
Nthill93
Long Island, NY
You won’t be disappointed. Tons of power and great trigger control.
RedneckWelder
Don’t get me wrong it’s a nice thing to have when you are away from air but to expect it to completely replace a strong 1/2 gun is wishful thinking at best particularly once you move beyond the automotive realm. It also seems to be a lot more wobbly/wants to throw itself around and off the bolt more than a good air impact as well, particularly when using extensions or wobble sockets.
The pneumatic gun is also good bit smaller and that often makes a huge difference as well.
dchawk81
I think the 2767 is great but it didn't really blow my mind because I already had the IR W7150 (the older brushed one) for cordless and the Nitrocat 1250k and MG725 in air. Plus a bunch of really good smaller ones.
I'm more impressed with the Avidpower from Amazon because of how cheap it was. It was like 85 bucks and can knock 12 semi shock bolts loose and back on with only one bar of battery. That's pretty good IMHO since they're 15/16 heads and nylock. I end up reaching for it first to find its limit.
I tend to grab the free air impacts first for similar reasons. It's more fun to be impressed by something cheap and cheerful than "well, yeah" with something expensive.
The 2767 also rattles too much to want to use it when not required.
Earp69
How's this sucker match up against the snap on version? I'm in need of a bigger one here soon
dchawk81
TTC tested them both on their channel. It's good but it's so expensive it's a tough sell, IMHO.
If you mean the electrics. That's my opinion.
I apologize if this was for OP.
