Hi all,
Ok so the 2125 QTiMax is the little brother of the IR 2135 QTiMax which is known, among a few others, to be unstoppable when working on a car. AFAIK there is nothing on a car that a 2135 won't break loose.
The 2125 is ratted for a little less than half the power of the 2135.
-> 332 ft.lbs of max torque in reverse vs. 780ft.lbs for the 2135.
Now my question is, what kind of stuff found on a car won't the 2125 break loose ? assuming a good air supply. What's the point of keeping a 2135 if one gets a 2125 ?
My second question is : why would someone want to get the 3/8" version of the 2125 over the 1/2 version ? From 16mm and up the OD of the socket is determined by the bolt size, and below that, the OD will be smaller on 3/8" sockets but how significant is that ? I would lean on the 1/2" size for square drive toughness but could this be the wrong call.
Thanks for your advise
cheers!
cheers!
