Bockscar
I know I am probably going to beat a dead horse.....looking at the IR compressor's at TSC....does anyone have any experience with them and would you recommend?....thanks for any feed back
I have one that runs an extremely busy 4 bay garage. We're open 14 hours daily!!!I know I am probably going to beat a dead horse.....looking at the IR compressor's at TSC....does anyone have any experience with them and would you recommend?....thanks for any feed back
This is bad information and ignorant to actual facts!!Do not get the compressors with the SS3 or SS5 pumps. They are poor quality. Those inline twin cylinder single stage pumps are hit and miss. The pressure switches are poor as well. Basically they are a cheap 60-80 galling compressor that IR puts a ridiculous markup on, because it has an IR badge on it… similar to something like the Quincy qt5. You pay for the name.
if you want a good IR compressor that isn’t over priced for what it is, you have to step up to something that has a T30 style pump, which will run you 2100ish, but is actually worth it, and is a solid compressor.
If you are buying from TSC, this is the compressor. I should warn you though, at a true 7.5hp compressor, it is more than most people need.
https://www.tractorsupply.com/tsc/p...-gallon-two-stage-air-compressor?cm_vc=-10005
Long story short, there are a lot of 3-5hp compressors I would prefer to anything from IR and Quincy in that size range.
I see way to many failures of the IR SS3 and SS5 pumps, and cheap pressure switches. IR makes some really great products, but their entry level compressors are not one of them, and are pretty poor value. There are better compressors for less money out there.
Same goes for the entry level Quincy stuff. I see lots of quality control issues with those. As of late, they seem to have trouble properly tightening fittings. Loose NPT fittings causing leaks. Over tightening compression fittings causing the transfer tube to crush and leak. Unfortunately, over tightened compression fittings often require replacing the gooseneck transfer tube between the pump and tank.
I have delt with these compressors enough to know what’s hot and what’s not. That isn’t to say they are all bad… but there certainly are more failures than there should be for how they are priced relative to other brands.
Such as what?This is bad information and ignorant to actual facts!!
1) This “special place and special land” I live in is called Michigan.
2) I’m glad you haven’t had anything wrong with yours, but that doesn’t mean they are all that way.
The biggest nuisance is the pressure switches on the consumer grade IR stuff. Most times when they fail, they simply won’t kick on when pressure drops below the limit. A couple times I have also seen the contractors weld themselves shut, and the pump won’t shut off unless you flip the breaker, of the TPOS on the motor trips.
the pumps are also have a couple quality issues. The two most frequent failures I see are valve plate gasket failures, and seized pistons. I suspect that these both are due to heat. Even though it only pumps up to 135psi, they still run very hot. Looking at the design of the casting, it isn’t too surprising because there isn’t much cooling fin area on the cylinders relative to other pump designs. I think IR was a bit optimistic with their 100% duty cycle.
3) “It's the best deal going for compressor to $$ value.” What about the 60 gallon SS3 is worth $800+? The switch is cheap and less than reliable, the pump isn’t great, tank is ASME rated just like any other 60 gallon take out there. The motor isn’t bad, to be honest. The Emerson TOPS motors seem to be on par if not a little better than the common Century motors on other consumer grade compressors… but it’s still no Baldor motor… I just don’t see $800 anywhere there.
4) I mentioned nothing about county of origin, nor did it lead me to give it a sour review.
5) 5 star reviews don’t carry much weight with me. Most reviews are posted relatively soon after purchase. It isn’t until you have a couple thousand hours on a compressor that you start to separate the men from the boys.
I agree. I’m an engineer and spent my life designing products shipped to the field. Long term reliability/design robustness is not the same thing as early life failures. Generally early life failures are a function of mfg quality control and long term reliability relates to cost of components. Both can be compromised in pursuit of squeezing out costs to be competitive but mfg quality control has more immediate feedback as it shows up in mfg yield, early life failures/returns. So it generally gets sorted out. As long the unit gets past the warranty period, long term reliability only shows up indirectly in the business as a customer sat. thing which is hard to measure and easy to debate internally as to cause.5) 5 star reviews don’t carry much weight with me. Most reviews are posted relatively soon after purchase. It isn’t until you have a couple thousand hours on a compressor that you start to separate the men from the boys.
The biggest nuisance is the pressure switches on the consumer grade IR stuff. Most times when they fail, they simply won’t kick on when pressure drops below the limit. A couple times I have also seen the contractors weld themselves shut, and the pump won’t shut off unless you flip the breaker, or the TPOS on the motor trips.
I've mentioned nothing to YOU about mine. Matter of fact I've discussed 866 other people not named me.I agree. I’m an engineer and spent my life designing products shipped to the field. Long term reliability/design robustness is not the same thing as early life failures. Generally early life failures are a function of mfg quality control and long term reliability relates to cost of components. Both can be compromised in pursuit of squeezing out costs to be competitive but mfg quality control has more immediate feedback as it shows up in mfg yield, early life failures/returns. So it generally gets sorted out. As long the unit gets past the warranty period, long term reliability only shows up indirectly in the business as a customer sat. thing which is hard to measure and easy to debate internally as to cause.
I only look at the negative ratings to see if there is a common thread in the type of complaints which may indicate weaknesses in product. For example, it seems a common thread in negative reviews on the TS4N5 IR is the motor failing out of warranty. You mention the motor on that unit isn’t a bad motor so that caught my eye as not what I was expecting from the reviews.
I’ve read ( that is urban legend on forums) that on lower priced models they run the pump and motor at higher RPMs to increase specs at expense of reliability. What I don’t know is what is high or if the urban legend has any validity. I see that IR 5hp all seem to have motor rpm @ 3450 and pump rpm around 1500. In 5hp range- Quincy, other than the qt54, have motor rpm @ 1750 and pump rpms around 900. Ditto on Eaton and other very expensive brands.
Do you think the lower Rpm designs are worth the extra cost from a reliability point of view?
I’ve been considering them just for the noise level and wondering if they are really any better from a reliability POV.
thanks for the advice
Why are you so defensive about this? It's great that you and 866 other people haven't had any problems but that doesn't mean they're non-existent. OP asked for feedback and experience, not for everyone to tell him that it's the best compressor in the world, sounds like you might be the biased oneI've mentioned nothing to YOU about mine. Matter of fact I've discussed 866 other people not named me.
As I've mentioned three times reviews...meh...i don't do them.
That said if this had 20 reviews ok...even 50..again that's not very much in the grand scope of things.
866 reviews is in fact something.
Moreover...you bounce around changing your tune about things. At first it was the compressor. Then you change to the switch and stress that.
Lastly and back to the reviews...
Sure someone might be excited early on with a positive review...
That said again you must be in fairytale land because they will just as equally jump back on there and say sonething like "update" or the like because ******** it they'll be heard!!!
I don't care where the OP buys the Air Compressor as I've no interest in this other to shoot them straight from an unbiased perspective and not ********.
866 reviews of 4.5 of 5 is something.
Meanwhile your suggestion is Harbor Freight junk!!
That's all you needed to say.![]()
When people speak from the angle of sour grapes instead of reality...Why are you so defensive about this? It's great that you and 866 other people haven't had any problems but that doesn't mean they're non-existent. OP asked for feedback and experience, not for everyone to tell him that it's the best compressor in the world, sounds like you might be the biased one.
That wasn't my suggestion but I guess you are on fire about your opinion and want to be sure it's expressed.866 reviews of 4.5 of 5 is something.
Aahhh..@Xcursion88 - I'm sorry, I should have been more clear I was asking @vanapplebomb for his opinion.
That said,
It is interesting however on the topic of how important reviews are and what they mean.
Harbor Freight compressor has a 4.8 out of 5, 98% people recommend it.
21 Gallon, 175 PSI Oil-Free Vertical Air Compressor
Amazing deals on this 21Gal 175Psi Vertical Air Compressor at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Which is it? - your opinion of Harbor Freight being junk is wrong or your opinion that ratings mean something is wrong?
I know I shouldn't have done that but too fun not to point it out. Sorry If I offend.
I'm not looking for emotional fight or debate - just interested in rational opinions.
I wasn't quite following you...and after looking back i fixed my erred statement....either oversight by me or Auto correct...either way it's fixed.@Xcursion88 - I'm sorry, I should have been more clear I was asking @vanapplebomb for his opinion.
That said,
Xcursion88, I gave three (3) specific issues I see with these compressors. The pressure switch, the valve plate gasket, and seizures… Sorry you didn’t like what I had to say about the compressors pressure switch.Moreover...you bounce around changing your tune about things. At first it was the compressor. Then you change to the switch and stress that.
Meanwhile your suggestion of Harbor Freight....
That’s a very good question. I have long suspected that the portable 115V compressors were someone else’s doing, but I have never been able to confirm or deny this suspicion. IR keeps their cards close to their chest with such things.Does anyone know at what size tank/hp rating IR actually manufactures the compressors on which they paste their name? There are many lower end box store compressors with IR labels built by other manufacturers.
jack vines
Again...you must be in a special place in a special land.Xcursion88, I gave three (3) specific issues I see with these compressors. The pressure switch, the valve plate gasket, and seizures… Sorry you didn’t like what I had to say about the compressors pressure switch.
Belaire/ABAC make a nice unit. Belaire has good assembly quality control, and ABAC supplies a real nice pump. I see a lot less failures with those Belaire units than I do with the consumer grade IR stuff.
Actually I've never been on FB. My kids just got me doing snap thing not long ago.The ******* contest in here is enough to make Facebook jealous
Yes, the Emerson TOPS motors IR uses are cheap motors, like the Century TOPS motors on other entry level compressors. They are pretty similar, 3540 RPM two pole motors. It seems like the Century motors either die soon, or last a long time. The Emerson motors seem to last a little longer before failing, but have a similar failure rate. At least that is my experience.I only look at the negative ratings to see if there is a common thread in the type of complaints which may indicate weaknesses in product. For example, it seems a common thread in negative reviews on the TS4N5 IR is the motor failing out of warranty. You mention the motor on that unit isn’t a bad motor so that caught my eye as not what I was expecting from the reviews.
Not just the little guys, but the medium sized 240-volt units also.That’s a very good question. I have long suspected that the portable 115V compressors were someone else’s doing, but I have never been able to confirm or deny this suspicion. IR keeps their cards close to their chest with such things.
Nothing unusual about it. Nor any different than a you tube channel showing X vs. Y vs. Z getting a half million views.kind of quaint the faith some have in reviews.
How could that possibly be?fwiw i have an IR SS5N5 that I bought back in 2004. it saw heavy use in my home shop. eventually it got moved to the warehouse, where it got left on, and the compression fitting on the copper tube feeding the tank from the pump let go, letting it run over a long weekend. It was hot. Changed the oil then. It's still running OK. I make sure the switch is turned off unless it's needed now.
my only complaint about it is that it is LOUD.
So, this unit turned out to be reliable, but things have probably changed over he last 17 years.
So as long as everyone agrees with your opinion then you'll stick around?…I’m still in Michigan.
Seriously, this is ridiculous.
If anyone else has questions or wants opinions, feel free to PM me, but I will no longer be contributing my experience to this thread.
Enjoy
Agree - I hit the ignore button on him so hopefully won't see more of that.Seriously, this is ridiculous.
Enjoy
I really liked the Polar/Eaton also but the shipping costs are so high it makes them really expensive - $775 to ship to Az.Personally I like the Polar/Eaton units, or cheaper HF with plenty of reviews and detailed info.
indeed they don't mean everything. High participation simply means a lot of people bought the item. If we knew the % of sales that were reviewed...now that would be far more helpful. Taking the F150 example, I'd expect far more reviews than for say, a Tundra. Yet many folks would consider a Tundra more reliable than an F150.Reviews don't mean everything but when participation becomes high it certainly should be factored.
The OP asked a question and I simply recommended looking at the reviews which is a far greater sampling of things than a few people on GJ.
