IR air Impact Titanium trouble
Worm
My IR Impact Wrench starts rotating as soon as i hook the hose. So i have to unhook the hose to get it to stop. What parts do I need to order? Theres not a specific kit, they r all different or i can buy seperate pcs. Idont know whats wrong with it or how to pose the question. It works fine other than that. I assume there is moisture in my tank. I am not the work on my own stuff kinda guy(city slicker u could say) Thanks in Advance
ex-x-fire
Sheboygan Falls Wi.
Mostly likely need to clean any grit that gets behind the trigger, might also have a weak trigger spring or a bad o ring at the trigger air valve. You can stretch the spring out a little.
W
Worm
Thanks
KenC
oklahoma
There is a kit that includes the inlet valve, O-rings etc. That is most likely what you need. I thing all the composite IR guns use the same kit.
