buffalobill
Looking for a good IR thermometer, don't want cheap, would like something that will last a few years. Suggestions?
I've had this Raytek for years. I bought it for working on cars. And when it's not doing that, it's in the kitchen! VERY handy for checking temps of hot cooking items.
Just for the heckuvit, I looked for this Raytek on Amazon, and I see it has 4.7 (out of 5) star rating. I guess most other folks like it too. It's $62.95 at Amazon.......
The good ones use a reflectivity coefficient you enter based on the density of material being measured. Can make upwards of a 25% difference in temp reading (i.e. steel manifold or rubber coolant hose)...
(SNIP) At that point, any no-name IR gun is going to be as good as a Snap On branded one.
The 52225-A Dual Temp Plus features both infrared and contact thermometer technologies. The infrared function includes advanced 30 : 1 optics to measure small targets at longer distances, laser targeting, programmable HI/LO alarms, adjustable emissivity and Lock Mode to capture temperature readings. The contact function offers a built-in K type jack and comes with a 3 ft. (1 meter) wire thermocouple probe.
Specifications:
• Non Contact Temperature Range: -76 to 1400˚F (-60 to 760˚C)
• Thermocouple Temperature Range: -83 to 1999˚F (-64 to 1400˚C)
• Field Of View: 30 : 1
• Display Illumination: Backlit LCD Color display
• Target Indicator: Single Laser Spot
• Emissivity: 0.10(10E) to 1.0 (100E)
• Resolution: 0.1˚F / 0.1˚C
• Modes: MIN, MAX, DIFF & AVG
• Accuracy: +/-2˚C (4˚F) or +/-2% of reading
• Thermocouple Probe Accuracy: +/-1% of reading or 1˚C (1.8˚F) whichever is greater
• Response Time: 1 seconds
• Power Off: Automatic after 60 seconds
• Battery Life: Approx. 14 hrs.
• Included Accessories: 2 AAA batteries, instruction manual, plastic molded carrying case and free dial thermometer
I don't trust any IR gun unless I KNOW the emissivity of the target--as in, read it on a spec sheet.
95% is flat black--like the coolant hose example already mentioned (unless you are the type that sprays your hoses with Armor-All). They are calibrated against a "black body calibrator"...~95%. Few things we measure are ever that non-reflective, but rarely does anyone compensate the emissivity setting.
A true 1.00 (100% emissivity) source would **** you in and deposit you in another dimension.![]()
My fluke has served me well. It has high,med,low options for emissivity. If you need balls on accuracy you should really use a contact type thermocouple.
