Irwin Vise grip hand tools, Felo ergonic screwdriver set
iandh
Hi All, I'm new here but a long time lurker. I just joined today to be able use the search function to find info about Knipex tools, and bumped in to the classifieds section.
I just didn't want anyone to think I joined just so I could take advantage of the classifieds section without participating in the forum.
Recently I quit/was layed off from my job of 10 years. Luckily I had enough smarts to build up a good savings in that time, and so had enough to get started with a somewhat successful business.
At my old work, I had access to an amazing shop, so the first thing I did once I was on my own was outfit my own shop. Unfortunately, I went totally nuts buying tools, and bought two sets, one for my portable kit and one for my home shop.
After a couple months to cool off, I found that wasn't really necessary.
I'm getting rid of these guys so I can pick up a Knipex Plier wrench set and some other odds and ends. I have over 40 trader ratings under this username at overclock.net, and over 200 ebay feedbacks under "ihacc" (I recently changed it from my name of several years to my new company name, I&H Accessories). I also have a verified paypal with a bunch of transactions on it.
Here's what I've got:
Prices include shipping via USPS first class. Shipping upgrade available for actual cost. Most of these tools are new or like new, only used a couple times to try out. The ones that are used will be marked with a percentage of wear, with a note about the wear.
If you aren't satisfied with any tool (as in I misrepresented the condition), return it for a full refund including return shipping cost (only applies to first class mail). I will discount heavily for combo deals, and if you pick up everything, I'll discount really heavily.
2% wear basically means like new. 50% wear is where I would replace a tool, and 100% would be unusable.
Felo Ergonic Screwdriver set (selling only as set) $20. The #2 Phillips is the only tool in this set I would consider notably worn. Even if you buy a replacement for that driver, this set is still considerably cheaper than the cheapest I could find. I really like these, but I prefer the Wera for my hand shape. They're similar, but I like the Wera better.
Large Flat, 5% wear, near new
Medium Flat, 5% wear, near new
Small flat, 5% wear, near new
X-Small flat, 2% wear, near new
#1 Phillips, 7% wear, good condition
#2 Phillips, 30-40% wear, usable but noticable wear on tip
Picquik Stubby multi-screwdriver,2% wear, $10 These are neat little drivers, and the bits are really nice quality.
Wiss 10" Tin snip, 10% wear, blades sharp w/no knicks/dings. Slight corrosion spots on blades, nothing major. Grips in good condition. $10
Irwin Vise Grip Adjustable Wrenches,2% wear, 10" $9, 6" $8
Irwin Vise Grip 8" Needlenose,2% wear, $8
Irwin Vise Grip 9" End cutter,2% wear, $11
Irwin Vise Grip 9" Crimper,2% wear, $11
Irwin Vise Grip 7" Diagonal,2% wear, $8
Irwin Vise Grip 9" Lineman's,2% wear, $12
Irwin Vise Grip 8" Slip-Joint,2% wear, $8
wbrian63
Houston, TX
Items received today. Well packaged, everything was as described in the original post, or better.
Thanks for the great deal.
I
iandh
Thanks for checking back in, good to hear everything arrived ok.
Enjoy!
