gagecalman
Is a DOB relay like the ICM206 at the condenser recommended for a residential split system?
I was also wondering if there's a produce that will help if the furnace is 120-volts because if the leg not supplying it is lost the 120-volt transformer will keep the DOB energized as well as the contactor but the compressor will stop. If the leg is energized quickly the compressor will start right back up which is not good and it could also rotate backwards.
