Is cheater pipes on bolt cutters okay or no?
mikey03
I had to use a bolt cutters to take an old padlock off and it was kinda hard. They are smaller like 24” version. I got it but had to use all my might. 🤣 in the future can I get some steel plumbing pipe to slide over each side or is that a bad idea for whatever reason?
zendriver
Indiana
Just watch where the knuckles can end up, when something lets loose. :lol:
24" kind of small for all but the smallest padlock. Cop and storage unit shows, seem to use the big-boys.
neophyte
Pennsylvannia
“Bolt cutters” have capacity ratings, and the “maximum capacity” is usually above what is easily doable with the tool.
The Felco Large Cable cutters actually have instructions on how to hold or brace the cable cutters for maximum efficiency while cutting, although I can’t find an image online, and I have no clue were I put the cable cutter instructions.
Generally, just buying a larger pair is easier, other than transport.
There are bolt cutters with folding handles nowadays for more compact carry.
You could try cheater pipes, but there is the possibility could could break the bolt cutter handles, and get injured.
whateg01
doo dah, kansas, usa
It's a slippery slope. Adding 6" to my 24" long cutters isn't likely to hurt anything. But if 6" more makes it a little easier, then adding 18" will make it way easier. But then if it's easier to cut that 3/8" rebar, maybe now I have the leverage to cut the 5/8 bolt? The extra leverage reduces the feedback that should tell us too much is too much.
Theother part of this is that the jaws only open so far and the best mechanical advantage is with the work right in the smallest part of the opening. But the end of the jaws is open much farther, so maybe there's an assumption that if I add pipes to the handles I can cut something that barely fits in the jaws. And then bad things happen to the tool
Retired dozer fixer
Leesburg Indiana
What the hell do you think will happen?? Won’t be good. Like destroying cutting tools?
RonnieC
Orlando, FL
I have a pair of Fiskars bypass loppers with extendable handles. The geometry of these means that at maximum extension, it is difficult to spread them apart enough to allow the business end to open fully for a larger branch. In essence you use the extendability to reach further away branches rather than for leverage.
impactims
If you have to exert yourself or use a cheater on bolt cutters, you are using the wrong tool for the job.
Even if it does cut the lock, you are stressing the hardware at the jaws. Ever restored vintage HK Porter bolt cutters? I have restored 3 or 4. It's always easy to tell when someone exceeded their capacity because the parts within the jaw assembly are always bent.
Use the correct cutters.
whateg01
Not always. Sometimes it's just in an awkward spot.
Beerhippie
Far NE Oregon
I often set them on the ground and stand on one handle.
Yeah, what could possibly go wrong?
48" vintage H. K. Porter bolt cutters. A two-by four base and a scrawny 150 lb hippie standing on the handle, trying to cut #5 rebar.
I'm also wondering how the hell you cut a padlock hasp on the ground when it's chained to a fence gate four feet in the air?
An angle grinder and cut-off wheel make short work of hardened padlock hasps.
rsanter
visalia ca
Per the design and the specs? No
real world, yes you can but be prepared to damage something or shorten their life
CR888
Modern bolt cutters in sizes 12"-42" will almost ALWAYS have the stock sizes range it can cut for soft stock and hard stock. Both hard and soft will have a HRC Rockwell range. Softer stock U can cut slightly larger than harder stock. Just read the specs that are etched into jaws or stamped into handles. If what your trying to cut falls within the guideline you shouldn't need cheater pipes. My guess is that if you need a cheater pipe, your going to damage the tool or break it. Just use the right size for the job that is good enough quality. My cutters are from Japan. Klein and many other tool co's sell Japan made bolt cutters these days.
neophyte
Pennsylvannia
One thing I would worry about when using cheater pipes is the sharp edge on the edge of the cheater pipes.
Those sharp edges could cause point loads on the handles, causing or eventually causing breaks or fractures at the point were the edge of the cheater pipe is applying pressure.
milky2k
Los Angeles CA
I think bolt cutters are the wrong tool to cut padlocks since most people will try to cut the shackle. That is hardened steel and you may end up breaking your tool. They're called bolt cutters not padlock cutters. You might succeed cutting a small brass lock body instead. Otherwise, you should use a grinder or try picking or shimming the lock instead.
Aileron
outside
attach a 1/4 ton come along between the handles! I've done it on pipe 2-4 ft pipe wrenches where you couldnt get you body in a good position for leverage laying on top a large boiler. If it breaks you needed to buy a bigger one anyway
zendriver
Indiana
Padlock shackles are only case hardened to prevent cutting from old school hacksaws and files.
Proper set of bolt cutters get the job done almost instantly
Wrong size tool is ineffective like anything else.
larry_g
oregon
I'm old, fat, and out of shape so I find that I use a lot of cheaters these days. 30-40 years ago I could get things done with out cheaters most of the time if I was using the tool for what it was intended. These days I need some help at times. So me adding a 6-8" cheater on an 18" bolt cutter is OK.
lg
no neat sig line
dnschmidt
Phoenix, AZ
With the advent of cordless grinders why worry about bolt cutters? A Walter cut off disc and a M18 grinder will cut anything. To me bolt cutters are an artifact of the past.
bonneyman
Desert SW
Or any sensitive part. With the longer handles I've seen guys brace it up against their thigh.
Yikes! :eek:
CV428
If the jaws are overhardened, they will shatter like glass if too much force is applied. I had an A2 shear die set explode because it was overhardened by a machine shop. When I say explode, it sounded like glass shattering and pieces went flying everywhere. We tested a piece and it was at ~65rc, so never tempered we assumed. Remade it to 62 and it lasted for years.
If you really want to gamble it, get your detail in the jaws, apply light pressure, wrap a towel over it, and then full send. At least if it explodes the shrapnel will be contained :)
If it was me, I'd break out a grinder.
finn
The UP, God's country
Battery powered angle grinder for the win.
Tools would generally considered to be properly designed if the length of the lever arm (handle) was designed in conjunction with the design of the pivot pins and cutting jaw capability.
There may be exceptions, is an unusually short Handel on one model for storage or access considerations, while using jaws and pins from a larger model, but that borders on poor engineering from the product production cost point of view.
Good engineering doesn’t allow for “overbuilding” in one area.
Demon4x4
Space City
Just don't be like me and get lazy, and put one handle on your chest, both hands on the far handle and compress.
The whole family calls bolt cutters 'rib breakers' now.
whateg01
Creating a bunch of sparks at the edge of a pasture where the grass is very dry can start a wild fire
