You hit it on the nose 120v 2000 watts. Nope don't and wont live in FL or any place that don't get snow I'm in the upper peninsula by Marquette MI.
So it sounds like I need to jump up to a 208/240V and around 5500 watts? What would be a good heater for 50ft of 1/2in pex with 500sqft to heat one line in and one line out ? Do they need to have pressure in the system in order for it to work?
Well its been put together for about a wk and I have been running it while out in the garage. I can run it for about 1/2hr to 45mins and then the coolant cools down to the point of I have to shut off the pump and let it heat back up.
You will never get this to work on a short term basis like running it while in the garage. Leave the pump run and monitor the temp in and out of the unit and the slab temperature. You can't warm the cement by filling it with a small volume of warm water. The heating element has only the capacity to raise the temp at a certain rate. It takes the better part of 24 hrs for a system to "stabilize" with changes to the floor temp. Your undersized system will need to try to get the slab temp up during the day/warm period so it has hours of retained heat to help it in the cold/night.
I like to use the return temp of the water as my guideline to where my slab is. The difference between the water going in the slab and coming out of the slab will tell you how close the slab is to being stabilized. Write it in a logbook and learn your systems characteristics.
Is the space an attached garage? Insulated? Floor insulation? Lots of variables and starting from a weak point.
My system is "poor boy" by many standards. I do run a boiler but only use manual valves to mix the hot and return water to circulate back into the floor. My shop is well insulated and the volume of concrete makes the system work fine for me. The temp may drop in sustained -30 and -40 spells but compared to outside it is still great. During spring and fall I shut the burner off and on depending on the weather and shop temp. That saves me jacking with the valves which are "touchier" to adjust. Since it is very slow to heat up and cool in the building this works fine. I should put an air temp thermostat to shut it off during these periods of transition in the event the shop is getting too warm.
With your small heating capacity and volume you don't even need the "mixing" setup.
Keep your electric cost in mind.
It does not need to be pressurized and if doing it like you are I would stay away from even thinking about it.
If you are only going to run it only while in the shop get an electric fan heater and have it portable to blow on you and your work as needed.
