Is it worth fixing?
jmv61
I bought a cool looking torque wrench a while back at an estate sale but I didn't notice that the tip doesn't rest at zero, but about 2.5-3 inch pounds going clockwise. It's an older CDI torque wrench, by what I've read it's a really good brand. So, is this fixable or did I get a decoration piece? Sorry for no pictures but my phone is acting up right now. Thanks for the help.
J
jmv61
Here's the pics I got while my phone decided that it will take pictures. You can see that it's a little off center, not sure if it's fixable.
Dr.JohnnyFever
I would test it at around 70 inch pounds with a known good wrench. If it is close - call it good.
Sam'sAutoParts
Northeast PA
Can't you just bend the tip back to rest at zero? IIRC the instructions manual on my CM wrench told me to do that whenever the pointer does not rest at zero.
Too slow..lol
finn
The UP, God's country
Just bend the pointer to align with zero.. A bending beam torque wrench like that never goes out of calibration because it relies on the structural properties on the steel used in its construction, which doesn't change with time or use. There are no moving parts to wear (unless the beam is severely damaged enough to change the cross section or fulcrum length)
Error comes in because it is often hard to read the pointer in actual use.
J
jmv61
For some reason I thought it had to be more complicated than that. Thanks
Charles (in GA)
50 mi south of Atlanta
Biggest concern is if someone exceeds the limits of the tool (aka using it for a breaker bar). That will permanently damage the beam. If you don't exceed the limits, the tool will never lose calibration.
Charles
