Actually, you have the misconception. Oil additives are used to control the temperature dependence of the viscosity. So, the 5W-30 actually does have the viscosity of 5W oil at cold temperatures and the viscosity of 30W oil at higher temperatures. Some smart chemists figured this out. That is the principle of multi-viscosity oil and that's what the major motor oil producers have been doing for the last several decades.
wrong. it a common misunderstanding, and i really dont want to get back into another ******* match about oil.
the first number in a multi grade oil is not a "weight" number. the 5w in 5w-30 does not reference 5 weight oil. the
w stands for winter, and for an oil to get a
w grading from the API, it must meet a low temp pumpability requirement, not a viscosity(weight) requirement.
here are some viscosity numbers to ponder over, you can see how the hot and cold numbers relate to the "grade" numbers. again, the first number has nothing to do with the weight of the oil.
0w-20
@ 104*(cold) 44.8 cst
@ 212* (hot) 8.7 cst
5w-20
@ 104*(cold) = 46 cst
@ 212*(hot) = 8.4 cst
straight 20wt
@ 104*(cold) = 54 cst
@ 212*(hot) = 8 cst
0w-30
@ 104*(cold) = 72 cst
@ 212*(hot) = 12.2 cst
20w-50
@104*(cold) = 166 cst
@212*(hot) = 18.5 cst
straight 50wt
@104*(cold) =222 cst
@212*(hot) = 20.3 cst
as you can see, a 20w-50 viscosity is triple that of a 20 weight oil at the same cold temperature. motor oil weight and the
w number are totally different API specs.
another question, what are the specs of a 0 weight oil that the 0w-30 oil would be at low temps?? where do i find this 0 weight oil? makes sense neither the 0 or the
w are oil weight related, and are a totally different API spec. i wish API had not used numbers, and used A, B, C, D, etc... as there would be less confusion and people naturally thinking that the number is a referencing a "Weight"
still dont believe? heres the API J300 specs for that pesky
w rating. top is regular API SAE and ISO viscosity ratings, and bottom are the cold temp pumpability
w ratings.
http://media.noria.com/sites/archive_images/backup_200211_viscosity-tab1-2.gif
to add more confusion... 10w-40 motor oil is the same viscosity as 80w-90 gear oil, but most people will swear gear oil is much thicker than the motor oil.... oil is full of misconceptions.
