You need an unloader too. Giant makes a good pump too. Go to pressure washer direct, Northern has good units also,,, need pressure relief valve as well. I have built some, this is a piece I would seriously consider buying. Rip the cord and go to work.
I built half a dozen in trucks for oilfield, a couple 11 gpm can run 2 wands and also used for injection work. I just build one a couple years ago from scrap parts but it is a hot unit and still have a couple issues need to be worked out with unloader sizing. It is an old obsolete size pump etc but the cost is way different as it is hot.
First pic is my shop unit, 5 hp electric, 2 and 3 are the salvaged engine drive goes in insulated truck with 500 gallons of water tank.
Water sand blast works well and do not need hot for it. A pressure washer if you have any real work for it is a good thing to spend up on, the reliability and the power make a good one so well worth it. GPM really gives it the cleaning power.
I know someone has a Northern electric diesel hot, want to try it sometime to see how well it works. You can do a lot of things with a pressure washer, heat makes it a different tool again especially in a cold climate or dealing with grease. Even washing bugs off a car, even during a simple rinse I often heat it up while coming around the front for windshield and headlights/grill.
If I had to replace my shop unit would go LP, if I was young would get a model 1 size larger yet but it is a factory deal and works so super well. I live on 2 miles of dirt road, wash a car most days, nothing like being able to flip switches to do it.
