Stupid homeowner question.
I bought my house in 2007 and had a serious fire in 2018. It didn't burn down, but the smoke damage was so extensive, it was torn down to the studs and repaired from there. All insulation was removed (all electrical, plumbing, everything).
Now, admittedly, I never had an opportunity to see it with insulation before or after. I saw it as studs and I saw it finished. But for the 11 years I've lived here, I've never experienced what you see in the attached photos. A layer of solid ice on the window, ice formations on the inside of the garage door and the electrical panel on the wall, and snow on my car that's been in the garage for > 24 hours.
I used a laser temp and the interior of the walls are -2 degrees C (28F) and it is currently -8.3C (17F) outside.
I paid extra to have the garage door upgraded from the standard R10 to R16 and my build contract says all exterior walls are to be R24. The roof is supposedly R50.
This is an attached garage, sharing 1 wall and the roof with the house. I don't know if it is useful information, but the inside of that shared wall is reading 18C (64.4F) while the other interior walls are reading 20C (68F) and that's also what my thermostat is set to.
I'm concerned that they either didn't insulate my walls or, if they did, they did a poor job of it or something else is wrong. But I didn't want to start a fuss without getting a more informed opinion. Maybe this is "normal" for current code construction? I asked my neighbors, who's homes were all build around the same time as mine in 2000-2007, and none of them have snowy cars in the morning or iced up windows, etc.
Thanks.
Thanks.
