Kent in KC
I'm building a new home in Kansas City, and don't think I'm getting a good A/C recommendation. Before I go out and get a couple more bids, I thought I'd see if any of you fellows could give me some advice regarding the size of the unit I would need.
Now, I know there is the Bubba method and the correct method for sizing a unit and the correct method involves a lot of inputs and calculations.
So, here is the basic sketch: it is a ranch with full finished basement, 3500 sq ft, 4BR, 3.5 bath, south-southeast orientation, Andersen low-E casement windows, (83 sq ft of windows on the south, 5 sq ft of window on the west, 55 sq ft of windows on the north and no glass on the east). The walls are 6", insulated with Icynene foam, all exterior doors are good fiberglass TemperTru (?). The living room has a vaulted ceiling up to 14' and two 2x2 Velux skylights. The roof has 24" overhangs and the underside of the roof is insulated (with Icynene) instead of the attic, so we're keeping the heat out of the attic. Entry to the house is through a closed foyer, garage or back porch that all act as airlocks to prevent rapid loss of cooled air.
I had them install the A/C outlets in the ceiling instead of the floor for more effective destratification.
The house is only shaded along the west side in late afternoon and sits atop a breezy hill. My wife is a teacher so during the summer 'vacation' the home will need to be kept comfortable during the hot part of the day (no thermostat setback).
Based on all that, does a 3.5 ton, 13 SEER central air unit sound right? Sounds big to me and I do not want an oversized unit.
BTW, before you recommend a heat pump, it ain't in the budget. I blew too much on solar heat and radiant floors!
Any advice would be appreciated. Thanks, guys.
