marklbucla
- Joined
- Dec 6, 2010
- Messages
- 18
Please see the attached image of my main breaker panel. There is a subpanel to the house, and another one to the garage.
It appears that I have a MWBC (two hots and 1 neutral wire between them), but there's only two outlets on it. The hot wires are connected to the circuit breakers in the red box, on the same level in the panel.
Are the two breakers on the same leg? This is theoretically incorrect, right?
Edit: added a bigger picture. In this situation, I'm referring to one part of each of the separate two switch breakers that are sharing a neutral.
) put only one outlet on each side of one of the MWBCs and then 1 outlet one one side and a bunch of outlets on the other. I don't expect to have anything hooked up to one side of each of the MWBCs, so I don't imagine that I'll get an overloaded neutral?
