Pull it apart and check that the backing plate is flat.
While obviously not the same ratchet, I had a Craftsman premium ratchet that had quite a bit of wobble. Turned out that the backing plate was bent slightly allowing the center to flop around a little. Few taps with a hammer solved the issue.
