I know there are number of very skilled guys on this forum and I'm hoping I could get a little advise.
The high limit switch (red button) popped on my electric water heater in my shop a couple of days ago. I reset the button and the water heater seems to be working fine. This morning I turned off the 30 amp 2-pole breaker and put a volt meter to the water heater to see what might be going on.
With the breaker open in the panel and when I test from each hot wire to the ground at the water heater I still read about 1.25 volts on one of the hot wires and about .25 volts on the other. I get the same results when I perform the same test at the feed panel.
So I performed the same test on other breakers in the panel, I shut the breaker off, tested each hot wire to ground the same way with the volt meter and I get the same results on all breakers.
This isn't right, right? I'd assume if all was well I'd read zero volts when a breaker is turned off. I'm a little concerned about this. Should I be?
Thanks in advance for any advise I can get.
Ken
Ken
If you are, you have it set on resistance, not voltage. Flukes do not like voltage when set to ohms!
