Is oxy-acetylene welding still used?
MoonRise
Oxy-propane uses oxygen at a 4:1 ratio to the propane (standard neutral flame).
Oxy-acetylene is darn close to a 1:1 ratio (technically, a 1.1:1 ratio for a neutral flame).
Oxy-fuel cutting of steel is only using the fuel for the preheat flame. Once the steel is up to 'kindling' temperature, the oxygen cutting jet is all that is needed (as long as you keep the travel speed consistent and 'correct' :lol: ).
Oxy-propane produces almost 2x the btu for the same flow rate as oxy-acetylene (2498 btu/ft3 for propane and 1470 btu/ft3 for acetylene). But the oxy-acetylene flame has a more 'concentrated' flame (more heat in the inner flame cone compared to oxy-other-stuff) and a slightly hotter flame temperature than oxy-propane.
Cutting speed difference between oxy-acetylene and oxy-propane would usually be barely measured in seconds (remember, the actual cutting is being done from the pure oxygen cutting jet and the fuel is only being used for the preheat flames).
Spiffers
Tennessee
I used to work for a company who made compressors for fridges/freezers and the copper lines were braze welded to the steel housing. I ran the machines that did the brazing. When they were installed they brazed the lines to tubes on the shell.
mbshop
visalia ca
I have a portable small setup.i don't weld much anymore. Use it more for cutting and heating. Home shop use. Neighbor was happy I had it. Don't know how anyone gets by without one. If I did a lot of welding then I would get something else.
mcbane
California
It's the ideal way to weld gas tanks after you fill them up with water.
Sounds like very costly hazmat disposal. 40 gallons of benzene contaminated water would need to be put in a drum, lab tested for characterization, then shipped to some place like Buttonwillow, CA where it can be part of a future superfund site. Maybe $500 per fuel tank to comply with regs.
u3b3rg33k
or sell it to racers for water injection. prob solved.
