Is pex al pex worth the extra money in a on grade concrete floor system.
PEX Tubing with Oxygen Barrier
Everhot Oxygen Barrier PEX Tubing is manufactured to ASTM F876/F877 standards and is pressure rated 100psi at 180F.
Barrier PEX can be used for a large number of radiant heating applications, such as radiant floor heating, snow melt systems, baseboard and radiator systems, fan coils, geothermal systems and for indoor or outdoor wood boiler supply and return lines.
***Barrier PEX features an Oxygen Diffusion Barrier per DIN 4726 standard, which helps to prevent corrosion of cast iron components of a typical heating system, such as circulator pumps, radiators, air scoops, pipes/fittings, boiler heating elements, etc.***
