Fredartic
I heard that some has sealed the floor with color and it's very nice. What do you think?
I used the colored sealer in a Gull Gray color. I don't know if it's better or not but I looked at "down the road". If for any reason I have to redo my floor all I have to do is clean it and apply new sealer. The stuff I used is a Xylene based product made by Butterfield. There will not be removing the old epoxy and no prep involved. I'm sure the more expensive epoxy's are good but if you read enough on this site you'll see where some have had failures with epoxys. I had 780 sq. feet of garage. I put three coats on in one day and the total cost of the sealer was $308 including shipping to my local concrete supplier from Aurora, IL. That was for 7 gallons and I have about 3/4 of a gallon left which I can use for "touch ups" if needed. The sealer will be good stored in the can for 2 years as long as it's stored properly. I'm happy with the way mine turned out.
I put a Xylene base sealer on my garage floor. The first time I put it down after a acid wash with an overnight dry. Held up pretty good for a couple years. I then put two more coats down to give a fresh look. a few months later I started using a mechanics seat with hard casters, doing detail work on vehicles. The stain could not take the point load from the wheels. I am over 200 lbs and the casters are cheap. If I had to do it over again I would make sure all casters are rubber, I prefer the yellow. I finally spent the money for a racedeck floor. The stain held up ok overall, but I could not put an epoxy or urethane over the stain. The rep at the paint store said it all had to come up if I wanted to upgrade to a harder finish. So I covered it with racedeck. I hope this helps....Good Luck
No I used a paint roller 3/8 inch nap. I had problems with air bubbles forming with the roller so I buffed them out with my floor scrubber and the black course pad. Then mopped the last two coats with a janitorial type commercial mop with bucket and wringer.
